Virallinen vikakoodi topic II
  • Jsj75
    • Sep 2011
    • 80
    • Hyvinkää
    #106
    Mitähän nämä vikakoodit taas meinaa?
    Potilaana on e61 530da
    Eka taitaa olla selvä tapaus eli hiukkaskiihdytin tukossa?
    E R R O R M E M O R Y
    Date: 04.10.2014 18:05:19 ECU: D50M57E0 JobStatus: OKAY Variant: D50M57E0
    RESULT: 2 error in error memory !
    480A 480A particle filter system
    Error counter: 1 Logistic counter: 39
    Mileage 220720 km Engine speed 1820.44 1/min coolant temperature 92.29 °C ash mass in particle filter 10.99 g Injection quantity 9.06 mg/Hub Air mass per cylinder 472.62 mg/Hub soot mass in particle filter 4.00 g exhaust volume flow in particle filter 309.29 m^3/h Difference pressure over particle filter 108.31 mbar Abgasgegendruck vor Particle filter 1132.30 mbar Environment pressure 1004.30 mbar
    Partikelfilter stark beladen (Abgasgegendruck ueber CRT-Schwelle) Test conditions not yet fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase
    Error code: 48 0A 11 02 00 00 01 27 6B C6 42 8E 0B 17 4B 04 25 0B 73 66
    4667 4667 particle filter system
    Mileage 220720 km Engine speed 1820.44 1/min coolant temperature 92.29 °C Rail pressure Actual 417.49 bar Injection quantity 16.15 mg/Hub Air mass per cylinder 516.73 mg/Hub Charge pressure Actualwert 1073.23 mbar Difference pressure over particle filter 108.31 mbar soot mass in particle filter 4.00 g ash mass in particle filter 10.99 g Environment pressure 1014.15 mbar
    zu haeufige Regenerationen Test conditions not yet fulfilled Error not occurred yet Error would not cause a warning lamp to light up Fehler in Entprellphase Fehler in Entprellphase Fehler in Entprellphase
    Error code: 46 67 14 02 00 00 01 27 6B C6 42 8E 35 29 52 6D 0B 04 0B 67
    DPF:n koodit olen nollannut muutaman kerran ja ajanut pitemmän lenkin että poltto varmasti onnistuisi mutta taitaa olla jo niin tukossa että ei auta. Lämmöt ok ja hehkut kunnossa eli ainakin pitäisi poltto onnistua.
    Tämä toinen on sitten vähän mystisempi. :think
    Koodit on aktiiviohjuksesta.
    Date: 04.10.2014 18:09:38 ECU: AFS_60 JobStatus: OKAY Variant: AFS_60
    RESULT: 3 error in error memory !
    6142 ECO-Valve im SGM
    Error counter: 90 Logistic counter: 0
    Mileage 220616 km ZFLS Error code 39.00 -- ZFLS Error type 0.00 -- Vehicle speed 46.00 km/h Lateral acceleration 0.00 m/(s*s) Yawing rate -0.01 rad/s Total steering angle 0.00 degrees Driver steering angle 0.00 degrees Supply voltage 14.12 Volt Engine torque 0.00 ? Various SG statuses 228.00 digital Engine temperature 25.00 degrees Celsius End stage temperature 19.00 degrees Celsius Shut-down the active steering bit 0 0.00 0/1 Shut-down the yawing rate control up to terminal change bit 1 0.00 0/1 Substitute value engine speed for ECO functionality bit 2 0.00 0/1 Slow reset of the steering angle after shut-down bit 3 0.00 0/1 Temporary shut-down of the yawing rate control bit 4 1.00 0/1 Temporary shut-down of the yawing rate control bit 5 0.00 0/1 Shut-down the active steering after 100 sec bit 6 0.00 0/1 Speed-independent steering ratio bit 7 0.00 0/1 Direction-independent steering ratio bit 8 0.00 0/1 Substitute value yawing rate for Servotronic, DME functionality bit 9 0.00 0/1 Substitute value lateral acceleration for Servotronic, DME functionality bit 10 0.00 0/1 Substitute value steering angle speed for Servotronic, DME functionality bit 11 0.00 0/1 Error in the driver steering angle or the engine position angle bit 12 0.00 0/1 Const. Substitute value for total steering angle bit 13 0.00 0/1 Error in the total steering angle or the engine position angle bit 14 0.00 0/1 Const. Substitute value for the driver steering angle bit 15 0.00 0/1 without Meaning 0.00 1
    No matching error symptom Test conditions not yet fulfilled Error present now and already stored Error would not cause a warning lamp to light up General Error
    Error code: 61 42 70 00 5A 00 6B B9 27 00 17 00 FF 00 00 B4 00 E4 5F 59 00 10 00 00
    CE9E Message (Engine torque 3, ID=0AA) from DME PT-CAN
    Error counter: 1 Logistic counter: 0
    Mileage 221312 km ZFLS Error code 59.00 -- ZFLS Error type 77.00 -- Vehicle speed 52.00 km/h Lateral acceleration 0.00 m/(s*s)
    Yawing rate 0.00 rad/s Total steering angle 0.00 degrees Driver steering angle 0.00 degrees Supply voltage 13.80 Volt Engine torque 0.00 ? Various SG statuses 228.00 digital Engine temperature 37.00 degrees Celsius End stage temperature 28.00 degrees Celsius Shut-down the active steering bit 0 0.00 0/1 Shut-down the yawing rate control up to terminal change bit 1 0.00 0/1 Substitute value engine speed for ECO functionality bit 2 1.00 0/1 Slow reset of the steering angle after shut-down bit 3 0.00 0/1 Temporary shut-down of the yawing rate control bit 4 1.00 0/1 Temporary shut-down of the yawing rate control bit 5 0.00 0/1 Shut-down the active steering after 100 sec bit 6 0.00 0/1 Speed-independent steering ratio bit 7 0.00 0/1 Direction-independent steering ratio bit 8 0.00 0/1 Substitute value yawing rate for Servotronic, DME functionality bit 9 0.00 0/1 Substitute value lateral acceleration for Servotronic, DME functionality bit 10 0.00 0/1 Substitute value steering angle speed for Servotronic, DME functionality bit 11 0.00 0/1 Error in the driver steering angle or the engine position angle bit 12 0.00 0/1 Const. Substitute value for total steering angle bit 13 0.00 0/1 Error in the total steering angle or the engine position angle bit 14 0.00 0/1 Const. Substitute value for the driver steering angle bit 15 0.00 0/1 without Meaning 0.00 1
    No signal or value Test conditions not yet fulfilled Error not present now, but already stored Error would not cause a warning lamp to light up General Error
    Error code: CE 9E 34 00 01 00 6C 10 3B 4D 1A 00 00 00 00 B0 00 E4 6B 62 00 14 00 00
    CEA0 Message (Status Power steering, ID=0E0) from SGM PT-CAN
    Error counter: 21 Logistic counter: 0
    Mileage 220808 km ZFLS Error code 61.00 -- ZFLS Error type 77.00 -- Vehicle speed 0.00 km/h Lateral acceleration 0.00 m/(s*s) Yawing rate 0.00 rad/s Total steering angle -12.00 degrees Driver steering angle 0.00 degrees Supply voltage 14.12 Volt Engine torque 0.00 ? Various SG statuses 228.00 digital Engine temperature 42.00 degrees Celsius End stage temperature 37.00 degrees Celsius Shut-down the active steering bit 0 0.00 0/1 Shut-down the yawing rate control up to terminal change bit 1 0.00 0/1 Substitute value engine speed for ECO functionality bit 2 0.00 0/1 Slow reset of the steering angle after shut-down bit 3 0.00 0/1 Temporary shut-down of the yawing rate control bit 4 1.00 0/1 Temporary shut-down of the yawing rate control bit 5 0.00 0/1 Shut-down the active steering after 100 sec bit 6 0.00 0/1 Speed-independent steering ratio bit 7 0.00 0/1 Direction-independent steering ratio bit 8 0.00 0/1 Substitute value yawing rate for Servotronic, DME functionality bit 9 0.00 0/1 Substitute value lateral acceleration for Servotronic, DME functionality bit 10 0.00 0/1 Substitute value steering angle speed for Servotronic, DME functionality bit 11 0.00 0/1 Error in the driver steering angle or the engine position angle bit 12 0.00 0/1 Const. Substitute value for total steering angle bit 13 0.00 0/1
    Error code: CE A0 34 00 15 00 6B D1 3D 4D 00 00 00 FF 00 B4 00 E4 70 6B 00 10 00 00
    Ohjauksessa en ole huomannut ajossa mitään erikoista.
    Janne
    G21 320da M-sport -22
    e61 530da M-sport -05
    • toNmbbA
      • Apr 2009
      • 2334
      Potilas e39 535, M62TUB35.
      Ensin antoi vikakoodia Catalytic converter bank 1 ja bank 2. Vikakoodit nollattiin, tuli uusi häiriövalo,--> Catalytic converter bank 1 ja nokan tunnistin bank 2. taas nollausta ja nyt vika taas vaithui ja tällä kertaa tarjoaa tälläistä:
      Eli mikä tuota nyt sit vaivaa?
      • Teme
        • May 2003
        • 94
        #108
        E36 M3 3.0, mallia ralli...
        Ei pystyy painaa kaasua olleenkaan, saammuu. Tyhjäkäyntiä käy toisinaan kohtuu ok.
        Joku vanhempi scanneri (sellanen mistä luetaan koodiselitykset paperista) antaa viaksi : 1A, taulukossa lukee: control unit supply, ei muita vikoja.
        Toista moottorinohjausboksia kokeiltu, ei muutosta
        Google löysi tollasta:
        "the full code is battery voltage/DME control supply unit.
        Usually a voltage regulator problem or Main relay problem.
        Relay powers DME and fuel pump "
        Tuleeko muuta mieleen?
        • 530dA Touring
          • Jun 2009
          • 50
          • Orimattila
          #109
          Elikkäs tälläistä vikakoodia pukkaa 330da -01.
          Onko tää nyt ihan lämpötila anturi vika vai jotain muuta? Sellanen ominaisuus ilmaantunu autoon, että tyhjäkäynnillä kierrokset nousee n.950 ja pysyy siinä muutaman sekunnin ja sitten taas palaa normaaliksi muutamaksi sekunniksi. Ominaisuus loppuu kun kone lämpenee :think
          330d XDrive -13
          330xdA Touring - 06
          330dA Touring -01
          530dA -00
          530i Touring -01
          328iA Touring -97
          530dA Touring -00
          528iA Touring -96
          316i Touring -97
          Ja pari 316 E30
          • Petteri80
            • Sep 2004
            • 578
            • raiq
              • Nov 2014
              • 26
              Bmw 318 d 2009
              Moi. Olen uusi jäsen täällä, ja viisaammat sanoi että täältä kannattaa kysely aloittaa. Mulla on yllämainittu auto E90 korinen 318D vm 09 ja seuraavanlaisia vikakoodeja lykkää, katkonaisena autocom testeristä:
              DF122 lämpötunnistin no3 relepiiri oikosulku +12v
              DF031 PAS asennusrele ohjainpiiri oikosulku +12v
              DF001 tietokone ruisku kalibrointidata
              Kaikki siis katkonaisia ja ajettaessa välillä moottorivikavalo sammuu ja saattaa parin päivän päästä syttyä uudelleen. Arvostaisin jos joku asiasta tietävä osaisi ohjeistaa minunkaltaista kädetöntä. Toki aina on marmoritiski mutta mielellään viimeisenä vaihtoehtona.
              X3 F25 30d M-Sport
              • Muurahainen
                • 9195
                Tuo kannattaisi luettaa jollain kellä on bmw:n omat softat.
                Vähän kryptisiä nuo autocom:n suomenkieliset vikakoodit.
                • bmw911
                  • Sep 2010
                  • 63
                  Pääseekö tämmöisellä piuhalla lukemaan vikakoodeja -95 e38 750? Pitää ilmeisesti olla ADS piuha kun normaalilla ei löydy juuri mitään tietoja?
                  Mistä olette itse ostanut noita? Myykö Suomessa joku näitä?
                  Entä pääseekö tuolla johdolla ja jollain ohjelmalla vaihtamaan mk1 ajotietokoneeseen kielen? Tällä hetkellä vaihtoehdot on ranska, saksa ja italia...
                  Vai vaatiiko esim. tämän johdon ja navcoderin?
                  • TPAtma
                    • Dec 2014
                    • 6
                    #114
                    Moro.
                    E87 116i 2.0 (N43B20 vissiinkin) 90kW, antaa kylmällä kelillä (+5 tai kylmempi) käynnistettäessä, tai toisinaan esim. tyhjäkäynnillä paikallaan ollessa vikakoodin
                    2A99 Crank shaft - outlet camshaft, correlation
                    Ei muita koodeja. Tyhjäkäynnillä seisoessa vikavalo ilmestyy samalla kun kierrokset nytkähtävät hieman alaspäin. Valo sammuu kun auton sammuttaa, syttyy taas joskus uudestaan kun syttyy, kuitenkin epäsäännöllisesti.
                    Auto toimii kuitenkin ihan normaalisti vaikka vikavalo palaisi mittaristossa.
                    Lämpimällä ja kuivalla kelillä ei muistaakseni vikavalo ole koskaan syttynyt.
                    Ehdotuksia?
                    • Crossmx
                      • 144
                      • Lahti
                      #115
                      Auto seisonut pari kk ja heti käynnistäessä syttyi luistonesto, abs ja käsijarruvalo palamaan.
                      Vikakoodeja inpalla:
                      89 low voltage
                      68 DSC passiv after ignition because of interference
                      114 pressure sensor (Offset)
                      Vähän pallo hukassa ja ensiviikolla pitäisi mennä leimalle.. Mistähän alkaisi ettimään vikaa..? Autona tuo e39 -00
                      e30 325i M-Tech I -86
                      e61 530i M-Sport -08
                      e30 318i 2d -89
                      e91 320d M-sport -06
                      e39 528i M-sport -00
                      e39 528i -97
                      Vikakoodien lukua Lahdessa!
                      • böntti
                        • Apr 2011
                        • 2860
                        89 low voltage
                        Jännite käyny liian matalana, aiheuttaa kaikkennäköistä "mukavaa" mutta ohimenevää harmia. Poistuko viat nollaamalla?
                        • Crossmx
                          • 144
                          • Lahti
                          #117
                          Poistu hetkeksi, vähän aikaa käytin autoa ja sitten alkoi taas palamaan..?
                          e30 318i 2d -89
                          e39 528i -97
                          • Dimosaurus
                            • Jul 2013
                            • 24
                            • Koski TL
                            #118
                            Ois oma E39 potilaana ja on tullut pohdittua et mistä/keneltä vois kysellä jotain sellaista laitetta tarvittavilla kaapeleilla ja softalla? Sellaista millä vois vikakoodeja poistella, softan syövereitä tutkia, testata ja tarvittaessa muokata? INPA? Jos ei kovinkaan kallis olis niin ostaisin ihan itselleni.
                            Ongelmana kaikennäköistä vikaa mm. webastossa, lämmönsäädön läpissä, penkinlämppäreis....
                            GM:n Tech:t on jonkin verran tuttuja mutta muuten tuo tekniikkapuoli on aika hakusessa.
                            t: Timo
                            E39 525 Da -00
                            • WSE1
                              • 3242
                              • Suomusjärvi
                              #119
                              Minkähän takia nuokin on pitänyt "suomentaa". Olisi edes joku Suomenkielinen autoalan tuntija kääntänyt, nyt kyseisistä käännöksistä ei ole mitään hyötyä "PAS asennusrele" aika vaikeaa on edes esittää hyviä arvauksia mitä tämänkin pitäisi tarkoittaa. Siinä sitten autocom ja vastaavien kielikäännettyjen testerien käyttäjät ovat ihmeissään kun "on se nykyauton tekniikka niin kovin vaikeaa" D
                              • aripaa
                                • Jun 2006
                                • 520
                                • Kuhmo
                                #120
                                Tuollaista heittää e39 540ia 7/96
                                E R R O R M E M O R Y R E P O R T
                                Date: 12/19/14 14:15:59
                                ECU: ZKE3_GM1
                                JobStatus: OKAY
                                Variant: ZKE3_GM1
                                RESULT: 2 errors in error memory !
                                86 relay sticking Signal MERHK to batt+ in the GM III
                                Error frequency : 31
                                Static error
                                Kaikki toimii normaalista, paitsi ohjauspylväs ei nouse eikä laskeudu kun lähtee tai tulee autoon, muistit kyllä toimii ja ohjauspylväs toimii manuaalisesti, ei sinällään haittaa mutta olisi hyvä jos toimisi, jossain pientä häikkää jota en ole saanut selvitettyä.
                                Ext. bmw:t
                                e28 518i -87
                                e34 518i -92
                                e39 540ia sedan 7/98
                                e39 540ia sedan 9/98
                                e39 540ia tour. 12/98
                                E34 525i Touring 7/92
                                Vikakoodien lukua/nollausta.
                                e39 540 ia sedan 7/96
