E39 kysymyksiä ja vastauksia XIII
  • peto2
    • 8294
    • Järvikylä (Nakkila)
    #481
    Taas vaihteeksi vuotaan syyläri Saako näihin kestäviä syyläreitä muualta kuin marmorilta? Tuo nykyinen on ollut jotain 3v Behr-Hella tekele. Nissensiä turha ehdottaa niiden syylärit ei vaan toimi kasissa, tästä löytyy paljon juttua netistä. Vuoto on vain siinä syylärin nipassa, mutta sitä ei BMW:ltä saa erikseen. Tarvikkeena tuota vielä saa, mutta harkinnassa kyllä jo syylärin vaihto.
    Kerro lisää tästä. Mulla on jäähdytin melko pullistunu ja juuri Nissenssiä meinasin ostaa Behr-Hellan huonon laadun vuoksi. :think
    Nakkaa privaa jos tarvetta.
      Esim. JimLev meni 3 Nissensin syyläriä ja sitten totesivat, että ei mene enää takuuseen: " Dear Steen,
      Again I find it necessary to write to you about the 3rd Nissens radiator I received from Taylor Automotive as a warranty replacement for the second radiator that leaked, which was a replacement for the first one that leaked. (Invoice # 606032 Customer # 122967)
      Yes, the 3rd one in a row has failed, this time it only took 2 minutes for it to start leaking from the very same place. The lower side by the bottom hose connection.
      They all have leaked where the plastic side tank is crimped to the aluminum core.
      The problem is not the car, the radiator cap has been replaced. The engine has never overheated, the coolant is changed every 2 years with BMW coolant and distilled water.
      This third radiator was shipped to me on 1/24/07 and installed last Wednesday. (my car is stored for the winter).
      I bought your radiator because I was told that the BMW Behr radiators had a history of the hose connections snapping off.
      At the time my BMW/Behr radiator was 5 years old so I thought it would be wise to replace it, even though it had no problems.
      On Thursday my old Behr radiator was put back in the car, I have been driving it all day today, not one drop has leaked from it.
      At this point I would like my money refunded from Taylor Automotive ($118.01), as I can not trust the quality of another Nissens radiator.
      Earlier today I ordered an all aluminum Zionsville radiator ($632) which has a lifetime warranty.
      I would expect that you would want to have these defective radiators shipped back to you for examination....yes?
      UPS can pick them up if you fill out a pick up ticket.
      Attached are 2 pictures of your 3 radiators and the old Behr that is now in my car, and the leak from the last radiator.
      The reference numbers on all 3 are 60648A.
      The production numbers are 165361 E, 204567 LF, and 392677 C2 C4.
      I look forward to you reply and also Taylor Automotive.
      If you need more info, please let me know.
      Eikä ole mitenkään ainut tapaus, googlella löytyy lisää. Kutoseen osalta en osaa kommentoida kun näissä on erilaiset syylärit, niissä ehkä Nissens saattaa olla toimiva.
      • peto2
        • 8294
        #483
        Olisko vialliset sitten 9/98 jälkeisissä koska tuota vanhemmissa on ainakin samat jäähdyttimet 520i-750i ja niitä olen nyt kahteen autoon laittanut ilman ongelmia toinen noista on edelleen taloudessa n. 5v myöhemmin :think
        EDIT: Eikä muuten ole, etk näyttää mitä sattuu..
          Juu ei ole samat, paisarit, termarikotelot jne suunnilleen kaikki erilaiset kutonen vs kasi. Kenties se kutosessa saattaa toimia kasissa ei. Siksi ajattelin kysäistä onko Behr-Hellaa parempaa olemassa muuta kuin alkuperäinen.
          • Pazi88
            • 11373
            Mut eikös orggis ole behr? Ainakin e36:ssa on. Behr tarvikkeet on mulla ainakin kestäny hajoamatta.
            Instagram, YouTube kanava
            • peto2
              • 8294
              #486
              Mulla on kolme behriä alkanut vuotamaan n. vuodessa. :think
              Mulla on E38:ssa tuo Nissens paikallaan ja se on ainakin kestänyt jo pitkään, sama jäähdytin kun alkupään V8 E39:ssä
              • zener
                • 14904
                Paljon on juttua joo tarvik behristä. Made in South Africa on kuraa.
                Tesla Model S 75D '17
                F10 520dA '11 klick
                E34 520iA (2.8l) '91 klick
                • holisti72
                  • Aug 2012
                  • 337
                  • Siilinjärvi
                  #488
                  Tuossa omassa sigun kulkineessa Nissensin syyläri, vaihdettu parivuotta sitten, ainakin toistaiseksi vielä pitänyt nesteet sisällään..
                  - Pena -
                  BMW E39 528iA -99 orientblau
                  ex BMW e34 525 tds -92
                    Mulla vuotaa Behr nyt siitä nipasta siinä syylärin päällä, siitä menee se ohut letku paisariin. Ikää on jotain 3v ja on jo tovin haistellut jäähdytinnesteen hajua. Kävin tilaamassa uuden Harkitaiselta kun BMW ei enää myy tuota osaa.
                    • tu22ha
                      • Dec 2012
                      • 13
                      Mikähän voisi olla 99vm 530d farkussa vikana kun auto ei sammu kun virrat kääntää pois jos parkit/valot on päällä?
                      Mittaristoon syttyy myös virrat himmeästi jos virrat pois päältä laittaa parkit päälle.
                      E61 535D LCi -08, E39 530d -00, E36 330D -93
                        Virtalukon pohja aiheuttaa ihmeellisiä ongelmia välillä. Kokeile meikkipeili testiä.
                        • tu22ha
                          • Dec 2012
                          • 13
                          Meikkipeilitesti?
                          Muistaakseni kumpaankaan meikkipeiliin ei tule valoja.
                          • TheRipper
                            • 5475
                            • Paimio
                            #493
                            Originally posted by tu22ha View Post
                            Meikkipeilitesti?
                            Kokeile liuttaa läppää ees taas...jos ilmenee outoja niin virtalukonpohjassa vikaa.
                            F10 523iA 2010
                            Ex: E39 528iA 1997
                            Ex: E85 Z4 2.5iA LCI 2008
                            Ex: E65 745iA 2003
                            Ex: E46 318i 1998
                            Ex: E34 525iA 1989
                            • tu22ha
                              • Dec 2012
                              • 13
                              Joo eipä siinä mitään erikoista tapahtunut, valot vain tuli sinne peilille kun polttimot laittoi.
                              • TNT
                                • Dec 2005
                                • 3527
                                #495
                                Olisiko kenelläkään mahdollista linkittää kuvaa E39 minkä alla olisi 17" vanteet 225/45 renkailla :think
                                Koitin kovasti googlettaa mutta ei osunut kohdille oikeanlaista kuvaa.
                                Originally posted by Jube
                                Eihän sen tyylikkäämpää ja parempaa autoa olekkaan kuin hienokuntoinen vanha kunnon w124
